jjse
Feb 04, 2019Aspirant
XR500 newbie question
Hello,
I'm interested in buying the NG XR500 from a seller, but noticed that, besides English, there is also French written on the box (so " Gaming Router" and " Routeur pour le jeu"). Will I have ...
Feb 04, 2019Guru - Experienced User
If you set the language to English, the router should work fine.
Thought you might have some problems should you go to get support and warranty support for it. Something you might ask NG official support about.
jjse
Thank you, I'l give them a call. Greatly appreciate your help!
- FURRYe38Feb 04, 2019Guru - Experienced User
:smileywink:
- Netduma_JackFeb 05, 2019NetDuma Partner
We also have plenty of guides, in English, for helping you to setup DumaOS optimally: http://support.netduma.com/en/support/solutions/folders/16000090646
- jjseFeb 05, 2019Aspirant
Thank you much!
