Pez_Beats
Dec 30, 2020Guide
XR500 Nighthawk - Flashing power light - Firmware issue?
Hi all, Hoping someone might be able to help as I'm currently at my wits end with my router and Netgear! I've seen this problem floating about in several discussions but i've tried everything to...
Dec 30, 2020Guru - Experienced User
many things can go wrong using tftp as well as its sensitive to timing. Sometimes you have to try several times.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
Pez_Beats
Dec 30, 2020Guide
Thanks, will give it another go and let you know if it works!
