Pez_Beats
Dec 30, 2020Guide
XR500 Nighthawk - Flashing power light - Firmware issue?
Hi all, Hoping someone might be able to help as I'm currently at my wits end with my router and Netgear! I've seen this problem floating about in several discussions but i've tried everything to...
Dec 30, 2020Guru - Experienced User
many things can go wrong using tftp as well as its sensitive to timing. Sometimes you have to try several times.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
Pez_Beats
Jan 08, 2021Guide
Hi!
I've tried the Tftp method again however still no joy. It seems to get halfway before saying that its not getting a response from the server. I'm holding down the reset button whilst i power it on and waiting for it to flash 10 times as per the instructions and tried different time intervals but nothing seems to work?
This is where it gets to before it stops.
and then this is what i get when it fails
- Netduma-FraserJan 08, 2021NetDuma PartnerI can't see the images as they haven't been moderated yet, could you upload to imgur and post the link please?
- Pez_BeatsJan 08, 2021Guide
No worries, hope i've done this right as i've never used Imgur!
https://imgur.com/a/QKUp3cQ- plemansJan 08, 2021Guru - Experienced User
have you tried nmrpflash?
I've had luck with that when tftp wouldn't work
