TwoTonYoda
Apr 29, 2018Follower
Xr500 Nighthawk A can not connect B should I update to Version V2.2.1.10. C. Update process
Xr500 Nighthawk new out of box. Windows 10 64 bit updated to current on hardwired unit. Current firmware V2.0.0.28.
Returned X10 and bought this today. Currently at the screen through initial...
techminds
May 16, 2018Aspirant
Returned X10 and bought this today. Currently at the screen through initial set up asking if I want to update to firmware V2.2.1.10
A. No connection
B. Should I update in this fashion or some other way such as extracting and uploading zip.
Error when connecting states. This site can’t be reached. Netflix unexpectedly closed the connection. ERR_connection_closed. Same error on a laptop, a Mac, a phone an iPad. Also same in chrome, Safari or IE. please help
Well you can try this method. This is more a common problem for everyone.
Go to Command Prompt by pressing windows key and X and select Command Prompt.
Now, just paste these commands one by one and after every command hit enter.
Commands: ipconfig /release
ipconfig /all
ipconfig /flushDNS
ipconfig /renew
netsh int ip set DNS
netsh winsock reset
Lastly, just reset your PC or the device and see if it makes any changes.
