TwoTonYoda
Apr 29, 2018Follower
Xr500 Nighthawk A can not connect B should I update to Version V2.2.1.10. C. Update process
Xr500 Nighthawk new out of box. Windows 10 64 bit updated to current on hardwired unit. Current firmware V2.0.0.28.
Returned X10 and bought this today. Currently at the screen through initial...
Netduma-Fraser
Apr 29, 2018NetDuma Partner
You have to complete the setup in order to initiate the internet connection. It should allow you to update to the latest firmware in setup. Then when you exit the setup wizard you'll have internet.
Netduma-Fraser
May 16, 2018NetDuma Partner
Has your issue been fixed? A user on the Netduma forum provided the following information for you:
I was also facing this error recently. And While searching about it found a solution which you can also use. It worked for me.
Go to Command Prompt by pressing windows key and X and select Command Prompt.
Now, just paste these commands one by one and after every command hit enter.
Commands: ipconfig /release
ipconfig /all
ipconfig /flushDNS
ipconfig /renew
netsh int ip set DNS
netsh winsock reset
Lastly, just reset your PC or the device and see if it makes any changes.
ipconfig /all
ipconfig /flushDNS
ipconfig /renew
netsh winsock reset
