Trippybbpie
Sep 28, 2021Aspirant
Xr500 nighthawk no internet
Internet randomly goes out around 1:30pm and is now 7:55pm and still cannot figure out why my internet randomly stopped working. Called ISP, ruled out it’s the router not communicating with modem. I c...
Sep 28, 2021Guru - Experienced User
what modem/gateway is it connected to?
What firmware is on the router?
Trippybbpie
its spectrum modem EN2251 model i believe it is, and firmware im not sure on the router because i cant even connect to it after a factory reset. So whatever the default firmware is after factory resetting.
- plemansSep 28, 2021Guru - Experienced User
the "default firmware" after a firmware reset is whatever firmware you had installed. It doesn't clear out firmware and bring it back to the original. Resetting only clears out settings.
- TrippybbpieSep 28, 2021Aspirant
oooh ok so yeah im not sure.. i cant log into the router anymore because it keeps saying no internet detected so i cant fully setup the router anymore.
should still be able to log into router.
try this.
power off the modem and the router and disconnect everything from both. even coax from modem.
Wait 2 minutes.
connect coax back to modem and power it on.
give it 2 minutes to fully boot.
connect lan port on modem to wan port on router.
power on the router.
give it a couple minutes to boot.
try setup.
