Trippybbpie
Sep 28, 2021Aspirant
Xr500 nighthawk no internet
Internet randomly goes out around 1:30pm and is now 7:55pm and still cannot figure out why my internet randomly stopped working. Called ISP, ruled out it’s the router not communicating with modem. I c...
Trippybbpie
its spectrum modem EN2251 model i believe it is, and firmware im not sure on the router because i cant even connect to it after a factory reset. So whatever the default firmware is after factory resetting.
Sep 28, 2021Guru - Experienced User
the "default firmware" after a firmware reset is whatever firmware you had installed. It doesn't clear out firmware and bring it back to the original. Resetting only clears out settings.
- TrippybbpieSep 28, 2021Aspirant
oooh ok so yeah im not sure.. i cant log into the router anymore because it keeps saying no internet detected so i cant fully setup the router anymore.
- plemansSep 28, 2021Guru - Experienced User
should still be able to log into router.
try this.
power off the modem and the router and disconnect everything from both. even coax from modem.
Wait 2 minutes.
connect coax back to modem and power it on.
give it 2 minutes to fully boot.
connect lan port on modem to wan port on router.
power on the router.
give it a couple minutes to boot.
try setup.
- TrippybbpieSep 28, 2021AspirantTrying this now (logged on my phone to message back and forth) will update to let you know what happens
