aj_la1
Aug 21, 2019Aspirant
Xr500 Nighthawk wired laggy and slow internet
Need help, I have Firmware version XR500 V2.3.2.56 My internet is not stable wired and wireless. Speeds with the modem is 111 download and 10 upload. Router does regonize this. But sadly when i us...
Aug 22, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the XR router is connected too?
- aj_la1Aug 22, 2019Aspirant
modem is arris and model is tm1602A
dont know what mfr
- Netduma_AlexAug 23, 2019NetDuma Partner
Are you using a computer? Could you download PingPlotter and show us a screenshot of your results?
Here's a guide: https://forum.netduma.com/topic/23881-ping-plotter-quick-guide/
- FURRYe38Aug 23, 2019Guru - Experienced User
Thats an Arris Mfr'd modem. Not the greatest modem IMO.
I would do as suggested with a PC directly connected to the modem and test pings. Take note of PLs and Errors. PLs are packet loss. Then connect the XR router in between the modem and PC and ping again.
Ensure there are no coax cable line splitters between the modem and ISP service box. Ensure your using good quality RG6 coax cabling to the modem. Have your ISP check the signal and quality up to the modem.
