weeswolf
Sep 15, 2021Aspirant
XR500 No 1733 Mpbs Option On 5Hz Band
The 5GHz band on my XR500 is limited to only "Up to 347 Mbps". There are no other speed options, only this one. Should I not have a 1733 Mbps option? My firmware is version 2.3.2.114.
- Sep 15, 2021
Yeah, as Plemans mentions, I'd suggest factory resetting as the issue occured after the update.
Netduma-Liam
Sep 15, 2021NetDuma Partner
Could you please try switching to channel 48 and check if you have that option?
If not, did you factory reset after installing the latest firmware? Did you upgrade recently?
- weeswolfSep 15, 2021Aspirant
I switched to channel 48 and clicked apply, but still only 347 Mbps is available as an option.
I did do an update last evening, the firmware now reads 2.3.2.114 and I did not do a factory reset - is that necessary?
- plemansSep 15, 2021Guru - Experienced User
Its worth trying a factory reset if the issue cropped up after a firmware update.
- Netduma-LiamSep 15, 2021NetDuma Partner
