Yas7
Dec 07, 2018Aspirant
XR500 no internet as red light flashing
Hi. When i restart my router, why is it when i let it fully load up, i got turn my XR500 on and i get a flashing red light which means no internet? I have to restart router multiple times to get...
Yas7
Dec 13, 2018Aspirant
Is there no known fix for this clear issue with the XR500? This product isn't exactly cheap and yet all we get told is to reboot or factory reset the XR500 and issue should ne resolved! How about no this isn't an acceptable so called fix! Why shall i keep having inconveniences caused cause netgear can't fix a clear issue??! Why shall i keep wasting time to do this fix?? Why shall i lose all my DENY list data and start ALL over again because netgears answer to this faulty issue is to factory reset?! If u can't give me answers or a fix without me losing my DENY list then ur most likely going to lose a customer too and I'll happily get a refund
Netduma_Jack
Dec 15, 2018NetDuma Partner
I’ve not heard of anyone else with this issue so it’s not a widespread problem. Have you tried switching out the Ethernet cable between your router and your modem?
Also, have you tried connecting to your modem when the red light is on to see if it still has an internet connection.
If your issue continues I recommend seeking a replacement from NETGEAR
