N3TW33K
Mar 01, 2020Aspirant
XR500 no internet
My router worked properly for the last +- year. Now since a week it doesn't work anymore. The wifi points are “working” you can connect to the network but they don’t have internet. Swapped the etherne...
Mar 01, 2020Guru - Experienced User
What modem is it?
Have you tried directly connecting to the modem or whatever your isp has setup?
- N3TW33KMar 01, 2020AspirantYes I tried that unfortunately without any succes. Not sure what model it is. Its one from ziggo from the netherlands
- plemansMar 01, 2020Guru - Experienced User
N3TW33K wrote:
Yes I tried that unfortunately without any succes. Not sure what model it is. Its one from ziggo from the netherlandsso directly connected to the modem, it doesn't work? If so, its a modem issue. not a router issue.
Model is kind of key as well.
- Netduma-FraserMar 02, 2020NetDuma PartnerAs above, if you're directly connected to the modem and it doesn't work then it is either a modem or ISP issue. I would advise getting in contact with your ISP first and see if they can determine anything from their side.
