xlr8r
Mar 05, 2018Luminary
XR500 no wifi devices will connect to internet
okay so just bought eth Xr500 and set up everything as per my old R7000 only thing is, NONE of my wireless devices will connect to the internet ???????????? pulling my hair out right now ...
- Mar 05, 2018Hello, you just made a post on our forum, here is what I said there: Factory reset the router from Settings > Administration > Back up settings and click erase. This should resolve the WiFi issue. Are they all connected but just no internet access?
Did you click Update on the device panel after you had given it a name?
Netduma-Fraser
Mar 05, 2018NetDuma Partner
Djimi
Mar 18, 2018Guide
I can't get the xr500 to work. Says connected but no Internet. Have reset the router and every time I put in my ISP pppoe settings. (username & password from plusnet) I just get this message. Help me please.
