xlr8r
Mar 05, 2018Luminary
XR500 no wifi devices will connect to internet
okay so just bought eth Xr500 and set up everything as per my old R7000 only thing is, NONE of my wireless devices will connect to the internet ???????????? pulling my hair out right now ...
- Mar 05, 2018Hello, you just made a post on our forum, here is what I said there: Factory reset the router from Settings > Administration > Back up settings and click erase. This should resolve the WiFi issue. Are they all connected but just no internet access?
Did you click Update on the device panel after you had given it a name?
Djimi
Mar 18, 2018Guide
I can't get the xr500 to work. Says connected but no Internet. Have reset the router and every time I put in my ISP pppoe settings. (username & password from plusnet) I just get this message. Help me please.
Netduma-Fraser
Mar 18, 2018NetDuma Partner
Djimi, there is no need to make multiple posts. I have already responded to you on the Netduma & Netgear forum.
I would highly recommend calling Netgears 24/7 English Support Line as they should very quickly be able to resolve the issue you're having. They are much more familiar with the Settings as they created it. Sign in here: http://support.netgear.com/and you should get a number to call.
- DjimiMar 18, 2018GuideSorry. I thought their would be different people on each forum. And I'm pretty desperate to sort this. Been trying for 2 days and still can't do it. This is on top of having troubles with the R1 & Plusnet for the best part of a year.
- Netduma-FraserMar 18, 2018NetDuma PartnerAs I mentioned if you call the support line you'll get it resolved very quickly!
