YoDaDDY
Dec 04, 2018Guide
XR500 NON STOP CANARY Error in Destiny 2!!!!
NAT type in xb1 shows open and all other things look good.
Cetury Link DSL Gateway set to bridge mode, cat5 from (modem) to xr500, cat 5 from xr500 to XB1.
Destiny 2 is the ONLY gam...
Dec 04, 2018Guru - Experienced User
What does the game Mfr support site say about this? If this is the only game that is experiencing problems and others are not, then I would contact the game Mfr support site to see if there is problems with there services.
- Netduma-FraserDec 04, 2018NetDuma PartnerYou need to use the Destiny Geo-Filter profile, this will disable Strict Mode which should then prevent the errors you're getting
