Hookset
Dec 04, 2022Aspirant
XR500 not able to use ethernet ports
Wifi works great. Ethernet when plugged into my PC shows "Network cable unplugged" in adapter settings and has not internet. The ethernet1 light is not on. This is also after i have tried disabling a...
Dec 04, 2022Guru - Experienced User
Try different port, lan cable or different PC or other device. Cat 6 is recommended.
Hookset
Firmware is V2.3.2.134
using the cat 5e cable that was included with the router. cat 6 is going from modem to router.
only numbers on the ISP modem are S/N: . CM MAC:. MTA MAC:
The modem is brand new, just got spectrum internet last week and the xr500 this week.
- Netduma-LiamDec 05, 2022NetDuma Partner
Can you try the ethernet cable from your PC to the XR in a couple of different LAN ports on the XR? That way we'll know if it's just an issue with the LAN port on the XR or not.
- FURRYe38Dec 05, 2022Guru - Experienced User
There's not brand name printed anywhere on the modem case?
Maybe a Hitron?
FYI, please don't post Serial numbers or MAC addresses in public forums for security reasons.
- HooksetDec 05, 2022Aspirant
the only name on the modem anywhere is Spectrum. its the default spectrum modem they give, just modem not a 2n1 router/modem
- Netduma-FraserDec 05, 2022NetDuma PartnerAny feedback on the suggestion from Liam?
