Jim_Albani
May 11, 2020Guide
XR500 Not Blocking some Devices
there are times I wish to block a device on the network and it's fairly straight forward to do, But for some reason, it doesn't seem to work out that way.. I'll go into the routers web page settings, I'll select Device manager from the left column, and pick a device that I want to block... For example, A tablet. I'll click on it, and on the right side of the screen a pane will open showing the devices info, such as Mac address, IP Address, Connection Type and the name of device.. Well, I'll click on "Block" and then "Save".. The Icon turns black and voilla it should be blocked... Well, not all the ones I select actually get blocked.. It will still be connected and able to access the internet. Some devices that i select to block will have to wait for 2-3 min before the blocking kicks into effect, and other devices, it doesn't do anything... This also applies to some of the ether wired devices such as the livingroom computer that's connected VIA Ethernet cable.. .As I mentioned The devices that I'm blocking are turning black after clicking on save, but it doesn't seem to make any difference with certain devices.. And an added note... I'm making sure that it's the correct IP addresses of the devices since I can't block by Mac Address.. . Have no idea why... Any help would be appreciated...
IP address reservations are needed for device blocking to work right.
Jim_Albani wrote:No they're connected directly to the routers wifi or Ethernet ports... I decided to take a chance and try something off the wall as I remember another router having a similar issue as well.. I tried reserving the IP Address of the devices that are having trouble blocking internet access to and now it seems to work but still not as quick as normal... My Cell phone now blocks within a couple of seconds where as the Samsung Galaxy Tablet seems to still take about 3-4 min, but at least it starting to block...
- Netduma-FraserNetDuma PartnerAre the devices that you're trying to block directly connected to the router either through WiFi or ethernet or are they connected to a switch or router behind the XR?
