Nikkimacv's avatar
Nikkimacv
XR500 not broadcasting SSID
So I setup my router for the first time today, and when I was trying to connect to it, I couldn't fine the SSID in the available in the Available Networks. The name that I do believe is my router does...
  • Netduma-Liam's avatar
    Netduma-Liam
    Mar 30, 2022
    OK, it sounds as though you'd be best to factory reset the XR and set it up from scratch.
    Could you please hold the reset pin on the back for at least thirty seconds, then allow it a few minutes to reset itself. After that, everything will be set back to it's default and you can then complete the setup wizard.
