gfsamoan's avatar
Dec 22, 2020
Xr500 not connect some devices to internet
For the last week 2 devices no longer get the internet, one that is connect to wifi says it is offline and the other is connected through a switch via an ethernet cable. Both an be found connected to...
  • gfsamoan's avatar
    gfsamoan
    Jan 02, 2021
    Finally sloved. I called Netgear since my replacement router is uder warrenty and basically had to hardcode the primary and second DNS servers as the one provided was too congeteted. Now everything is back and running.
    Greg
