Ewim89
Sep 12, 2020Follower
XR500 not connecting to wifi
Hi I’ve reset my router and it is not connecting to my WiFi.
Ego556
Sep 12, 2020Aspirant
it's not connecting to your wi-fi? are you using it as something other than a router or did you mean it's not broadcasting wi-fi? is the wi-fi button on? what dumaos version?
- Netduma-FraserSep 13, 2020NetDuma PartnerAfter you reset it did you re-enter the default password for the WiFi on your device? It will have reverted to the password located on the sticker on top of the router.
