Sammcskimming
Mar 18, 2020Tutor
XR500 not detecting internet
Hoping for some help I have connected my XR500 to my fibre modem and the internet light on the modem is a solid orange (amber for those who call it that). I have tried everything I could find on ...
Netduma-Fraser
Mar 18, 2020NetDuma Partner
Do you know if you use PPPoE or VLAN? I would suggest copying the WAN Settings from the previous router and putting that into the Internet Setup on the XR and it should work.
Sammcskimming
Mar 18, 2020Tutor
The settings are PPPoE, have tried entering the recommended WAN settings from my ISP but that didn't work either. Might try this though, its worth a shot
