ficlet
May 18, 2023Tutor
XR500 not displaying traffic prioritization
Hey there! I'm running a XR500 and am having trouble getting my ping down/stable while gaming with Sea of Thieves. My friends report pings in the 50-60 range while I consistently am between 90-15...
May 18, 2023Guru - Experienced User
What browser are you using?
Try MS-Edge or Firefox?
What FW version is loaded?
ficlet
May 18, 2023Tutor
I'm using Chrome but can try Edge or Firefox. The FW is V2.3.2.134.
- ficletMay 18, 2023Tutor
Still doesn't work in Edge or Firefox.
- Netduma-FraserMay 19, 2023NetDuma PartnerGo to the System Information page and then in the Rapp panel menu ≡ change the retries to 5, reboot from the interface, wait 2 minutes before accessing and see if it works then please.
- ficletMay 19, 2023Tutor
Thanks for the response! I tried upping the number of retries to 5 but there is still no change, it's just an endless loading wheel.
