ficlet
May 18, 2023Tutor
XR500 not displaying traffic prioritization
Hey there! I'm running a XR500 and am having trouble getting my ping down/stable while gaming with Sea of Thieves. My friends report pings in the 50-60 range while I consistently am between 90-15...
ficlet
May 21, 2023Tutor
Tried loading without forced HTTPS, no luck. It's still not loading.
Netduma-Fraser
May 21, 2023NetDuma Partner
Make an account on forum.netduma.com and let me know your username, then I can add you to the beta and see if that resolves it
- ficletMay 21, 2023Tutor
I registered on forum.netduma.com but it's not sending me a confirmation email. I've tried to have it resent twice without luck. Checked the spam folder, it's not in there.
- Netduma-FraserMay 21, 2023NetDuma PartnerWhat's the username you signed up with? I'll manually approve the account
- ficletMay 21, 2023TutorThanks, I appreciate it. User name is ficlet.
- Netduma-FraserMay 21, 2023NetDuma PartnerI have approved the account and granted access, you should see the section when you login
Thanks, that got it working again!
