NorCAL2700
Dec 13, 2018Aspirant
XR500 not finding closest server anymore
So i have the XR500 and have everything set according to the "Optimization tips and tricks for Fortnite" guide. My issue is that I live in Northern California where one of the NA-West servers is loca...
- Dec 13, 2018
**Update: I tired switching server regions in-game to "Auto" and my ping is back to normal and the NorCal server shows up again. I had the server region on NA-West, but for somereason instead of connecting me to the closest server on NA-West it was automatically defaulting me to the Orgeon server each time.
Netduma-Fraser
Dec 13, 2018NetDuma Partner
I know a few days ago there was a notice in game to use the Auto region as they were having issues with specific region selections so thats likely why
NorCAL2700
Yeah i think their matchmaking is in need of a tune-up. According to the Auto and NA-West region matchmaking i should be experiencing about 16 ping (NorCal servers) yet i keep getting put into the Oregon region and experiencing 40-50 ping so obviously I'm being put into the wrong region. I switched to Auto matchmaking earlier today and i was put into the NorCal servers for 2 matches, but then i was placed in Oregon servers after that. I keep playing with the regions and switching between Auto and West, but no luck. Ive joined probably 30 matches today with only 3 of them being placed in NorCal servers. Im guessing I'll just have to wait until Epic solves their server issues once and for all.
- Netduma-FraserDec 13, 2018NetDuma PartnerAlthough they're having issues try using the Geo-Filter to force NorCal servers
- NorCAL2700Dec 13, 2018AspirantI have been using geo-filtering the issue is when I activate FILTERING the game tries to connect to the Oregon server, gets stuck on loading then kicks me back to the lobby screen with an error message that says there was a network connection issue since i dont allow it to connect to the Oregon server. I keep trying join matches for 10-20 minutes encountering the same error message until i am forced to switch to SPECTATING to be able to play and of course its on always on the Oregon servers.
- Netduma_JackDec 15, 2018NetDuma PartnerAnother user has said the same - so it sounds a lot like Fortnite are using the Cali server far less (or perhaps have discontinued it for now). When did you last see it, if ever?
