-Diamond-
Aug 25, 2020Tutor
XR500 not giving full download speeds via ethernet
So recently I have upgraded my internet to 400 mb/s and I use the modem that came from my ISP. Well my wireless speeds perform WELL better than expected at over 410 mb/s download and around 23 mb/s u...
- Aug 26, 2020Brilliant thank you, port 1 is limited to 100Mbps so that could be why you're experiencing slower speeds on that port, if you use a new cable - go back to check its at 1000Mbps for link speed and do a speed test do you get higher?
Netduma-Fraser
Aug 26, 2020NetDuma Partner
Could you provide a screenshot of the table view of your Device Manager please?
- -Diamond-Aug 26, 2020Tutor
- Netduma-FraserAug 26, 2020NetDuma PartnerClick the 3 line icon in the top left of the panel and select the table option, can I see a screenshot of the table view please?
Of Course! I apoligize I never noticed this as an option before
