maxgro's avatar
maxgro
Guide
Jan 10, 2020
XR500 not letting NAS connect properly to the internet
Hi all,
I found out that my NAS isn't working properly anymore since I changed from an R7800 (X4s) to the XR500. I have a WD MyCloud EX2 Ultra NAS which has an AppStore, there the apps no longer show up, meaning it's not connecting properly to the App Store of WD. Next, I also found out on the drive that I cannot register new users for cloud access because the NAS cannot send the confirmation email that's needed for setup.
What's interesting though is that partly the online connection works, because when I access the files manager though the WD web browser interface, I can see all my files there, indicating the connection works partly. It's possible that this is routed through a different port.
I was on the phone with WD support and also had a remote support screen sharing session and in the end, WD said that they checked everything and all diagnostics. When they asked me when these issues started I remembered that I bought a new router and this is the first time I actually tried to connect to the NAS via the internet since I need to update the Apps on the NAS.
Are there any settings that I have to change, ports I need to forward to let the NAS access the Internet properly?
  • Do you have the NAS connected via ethernet cable to the router? The devices you're trying to access it with are they using WiFi? If you use a wired device to connect does it work correctly? To rule out port issues you could put the NAS IP in the DMZ function in WAN Settings and see if it works then.
    • maxgro's avatar
      maxgro
      Guide
      The device is connected with Ethernet cable on port 1, I also tried another port just in case, but that of course didn't change anything.
      I have never setup a DMZ server before on my local network the NAS is assign IP 10.0.0.3. So what I did, but maybe incorrectly, is to setup a DMZ server with this IP. The issue remained.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        You did that correctly so that's not the issue, you can remove it from the DMZ now. Go to the QoS page, in the Anti-Bufferbloat menu (3 lines top left of the panel) disable QoS completely and see if that resolves it please.
