Cholete
Apr 26, 2021Aspirant
XR500 not searching lobbies in cold war
So from one moment to another the router started to not search lobbies, i have reset the router and still happens the same! Any solution? Thank you
Cholete
it only happens in cold war! Ping heatmap not showing any server and every other game listed shows servers... Solution?
- Netduma-FraserApr 27, 2021NetDuma PartnerAre you referring to Ping Heatmap, the Geo-Filter or both? We're aware that Ping Heatmap is failing to ping servers and we'll be pushing a cloud update to fix that so should be done within the next two days.
