jordy787
Mar 31, 2019Guide
xr500 not showing moca 2.0 devices
I have a xr500 and Just setup moca 2.0. I am using a linksys lgs105 unmanaged switch so I can connect my xbox and pc through moca.. anyways they dont appear to be displaying under devices on the rout...
- Apr 02, 2019
I got it to work, I did not know I have to plug the moca ethernet into a specific port (port 5) on my unmanaged switch. All devices are showing after doing that. Sorry about that
Netduma-Fraser
Apr 02, 2019NetDuma Partner
What firmware version are you on? Did it work at all on DumaOS?
jordy787
Apr 02, 2019Guide
- FURRYe38Apr 03, 2019Guru - Experienced User
What is the Mfr and model# of the ethernet switch?
- jordy787Apr 03, 2019Guide
linksys lgs105. I had to plug my moca ethernet to port 5 and all other devices go to port 1-4.
I would look at the user manual for the switch to see why port 5 is specifc for this. I presume it maybe the IN/OUT data traffic handling of some kind that port 5 does over the other ports. Glad it's working though.
Enjoy. :smileywink:
