Nikkimacv
Mar 29, 2022Aspirant
XR500 not showing SSID
So I bought one a couple weeks ago, and I just got my internet installed today, but when I hook up the router, it isn't showing that SSID on the bottom that it should and appears to be displaying as a...
Mar 29, 2022Guru - Experienced User
a couple things.
1. you might have better luck in the gaming forum for your device.
2. Did the wifi on/off button get hit? Try pushing and holding it for 2 seconds.
- NikkimacvMar 29, 2022AspirantI dont think the wifi on/off button got hit, I assumed it did so I had tried holding it for a few seconds a few times. It's mainly that what is showing up for the router just isn't the proper name and it isn't taking any of the passwords that it should be.
And I'll put a post in the gaming forum, but it's mainly the initial setup part that isn't working properly.- Netduma-LiamMar 30, 2022NetDuma Partner
Hey, I've replied to you in the new topic you created. Let's continue there.
