Killak786
Jan 05, 2021Guide
Xr500 on Virgin gig1 not reaching speed
Hi. Ive recently upgraded to gig1 package from virgin media. I have the hub4 in modem mode with the xr500 as my router. I am getting 950mbps at the modem but only 500mbps via wifi and ethernet. I h...
Netduma-Fraser
Jan 05, 2021NetDuma Partner
I'd suggest going through the setup wizard again on the XR so it can adjust any settings required for it, what does the speedtest report there that you get?
- Killak786Jan 05, 2021GuideI did the setup again and i got 915mbps on the setup speed test and 654mbps on the speed test after it had been setup.
Also on the netgear nighthawk app the speed test gives me 950mbps?- Netduma-FraserJan 05, 2021NetDuma PartnerOkay that's much better. I believe the Nighthawk app does the speed test directly from the router, similar to the setup wizard. Disable Smart Connect and connect to 5GHz manually and it may be faster.
- Killak786Jan 05, 2021GuideIve had smart connect switched off and im connected to the 5ghz but im getting max 650mbps?
