Killak786
Jan 05, 2021Guide
Xr500 on Virgin gig1 not reaching speed
Hi. Ive recently upgraded to gig1 package from virgin media. I have the hub4 in modem mode with the xr500 as my router. I am getting 950mbps at the modem but only 500mbps via wifi and ethernet. I h...
Killak786
Jan 06, 2021Guide
I got about a 20mbps increase with that method.
Netduma-Fraser
Jan 06, 2021NetDuma Partner
Okay interesting, now in router mode set the XR to AP mode, what speed do you get then? That will basically disable most router functions.
- Killak786Jan 15, 2021GuideI have tried what you have suggested but still the same. I have also tried bridging the xr500 with virgin media hub4 in router mode with wifi disabled but still the same. ?
- Netduma-FraserJan 15, 2021NetDuma PartnerWhat do you get via ethernet to the XR exactly?
- Killak786Jan 15, 2021Guide930mbps on average sometimes higher sometimes a bit lower
- Netduma-FraserJan 16, 2021NetDuma PartnerOkay that's really good. For some reason I just don't think it's going to be able to reach higher than what you have achieved on it so far. That speed is very sufficient for whatever your needs are but if you need more then you may want to get an AP or extender for example that can reach higher speeds.
