JohnSmith12345
Nov 08, 2018Follower
Xr500 only and only returns self on DNS resolution
XR500, latest over the air firmware
Router is configured with a static 'wan' public DNS IPs. Name resolution apparently works for the router itself as it was able to find the firmware update.
DNS r...
- Nov 13, 2018
I managed to get this working by resetting and auto detecting the internet settings instead of entering them manually
Netduma_Jack
Nov 08, 2018NetDuma Partner
Hi John - have you ever edited this section on your router, or did this just happen in the upgrade? This is NETGEAR's area, not Netduma (who I work for), so might be worth contacting official support if this is causing you particular problems: http://www.netgear.com/support/contact.aspx
