JohnSmith12345
Nov 08, 2018Follower
Xr500 only and only returns self on DNS resolution
XR500, latest over the air firmware
Router is configured with a static 'wan' public DNS IPs. Name resolution apparently works for the router itself as it was able to find the firmware update.
DNS r...
- Nov 13, 2018
I managed to get this working by resetting and auto detecting the internet settings instead of entering them manually
Nov 08, 2018Guru - Experienced User
NG uses DNS Relay or Proxy, even though you set up custom DNS on the router, the DNS that appears on all connected client devices will be the IP address of the router.
- cooties116Nov 13, 2018Initiate
I am having a similar issue. I can ping 8.8.8.8 and get a response, however, when i try to ping a domain (eg www.google.com.au) I only get the router IP in response (ie 192.168.1.1)
This is still the case when i set the DNS to static (8.8.8.8)
- FURRYe38Nov 13, 2018Guru - Experienced User
Good to know. Thanks for letting us know. Please mark this thread as solved so others will know.
