JohnSmith12345
Nov 08, 2018Follower
Xr500 only and only returns self on DNS resolution
XR500, latest over the air firmware
Router is configured with a static 'wan' public DNS IPs. Name resolution apparently works for the router itself as it was able to find the firmware update.
DNS r...
- Nov 13, 2018
I managed to get this working by resetting and auto detecting the internet settings instead of entering them manually
cooties116
Nov 13, 2018Initiate
I am having a similar issue. I can ping 8.8.8.8 and get a response, however, when i try to ping a domain (eg www.google.com.au) I only get the router IP in response (ie 192.168.1.1)
This is still the case when i set the DNS to static (8.8.8.8)
cooties116
- FURRYe38Nov 13, 2018Guru - Experienced User
Good to know. Thanks for letting us know. Please mark this thread as solved so others will know.
