DankPro
Nov 29, 2022Tutor
XR500 only has usb2 light soild
Okay so I have a xr500 night hawk router that when powered on no other light come on but the usb2. The led switch on the back is on. Now if I plug in my cable from the back of my computer to port 1 o...
Nov 29, 2022Guru - Experienced User
What happens if you disconnect everything from the router and press the reset button for a full 10 seconds then release.
The POWER LED should be on soon after the reset beings.
Check the volts and amps at the tip plug in to be sure that the volts and amps seen are what is on the power adapters sticker.
Have you access the routers web page at 192.168.1.1 after the reset happens after about a minute?
DankPro
Nov 29, 2022Tutor
The power adapter is the oem 12v 3.5amp. Now with nothing connected to it then a power cycle with only the power hooked up all the leds on the right half light up then go off and im stuck with only the usb2 led on solid. the reset button seems to do nothing when pressed for 10sec.
