Ahulee
Oct 08, 2020Aspirant
Xr500 open nat
Am trying to make an static route to my PlayStation but when I select it and put all the ips the destination up don’t let the process continue, even tho I have check and am putting the correct one
Netduma-Fraser
Oct 08, 2020NetDuma Partner
You don't need to do a static route. In WAN Settings just change NAT to open.
Ahulee
Oct 09, 2020Aspirant
Yes but in call of duty still says moderate nat and have internet problems stills
- Netduma-FraserOct 09, 2020NetDuma Partner
What is your exact physical setup? Are you using the Geo-Filter? What internet problems are you having?
- AhuleeOct 09, 2020AspirantYes am using geo filter for 2700 km.. I live in Puerto Rico and am using a “Claro gateway of fiber like the one used is USA like at&t. Y got it with pan to my ps4 but there no option I can pick that give me open nat, I have tried for days
- Netduma-FraserOct 09, 2020NetDuma PartnerCan you put the gateway in bridge or modem mode or does it have a DMZ function?
