Specop
Nov 12, 2018Aspirant
XR500 OpenVPN issues
When setting up OpenVPN I am getting a client side error that reads...
No server certificate verification method has been enabled.
Any thoughts on how to resolve this?
I've checked to make sure the router firmware and software are up to date. I've also regen the openva package with no luck.
As far as the logs, the only other line in there is "Enter Management Password:" but I never see that in the status. Just the error mentioned above.
Thanks.
Hi,
Have this problem also. Was advised to do a hard reset after a long conversation by Netgear advisor but still didnt work for me. Gave up in the end because they obviously dont know what there talking about and singing from the same hymn sheet.
- Netduma_JackNetDuma Partner
Is this in the VPN Client area that you are seeing this?
Being able to choose an OpenVPN client is coming in the next firmware on Hybrid VPN (which allows you to apply your OpenVPN provider to any device, game or port range)
Hi,
No, this is the VPN Service which I think is on the Netgear side of things. Exporting certificate for everything else seems to work. Only the windows exported certificate is affected.
