MrSwann
Nov 11, 2020Aspirant
XR500 OpenVPN suddently not working
Hi all My OpenVPN server suddently stopped working, can’t connect. I tried with ddns, didn’t do anything. I tried redownloading configs, didn’t help either What can I do ?
Netduma-Fraser
Nov 11, 2020NetDuma Partner
Has any part of your setup changed - physically or setting wise? What is your exact physical setup?
- MrSwannNov 11, 2020AspirantNo, i got the unit and ran the setup etc. It worked fine for about a day, then it stopped working. Not I can’t connect either via phone nor pc. Also the profiles for pc doesn’t work, so I tested using mobile profile and that also worked shortly as I recall
- Netduma-FraserNov 12, 2020NetDuma PartnerWhatever VPN client you're using to connect with these configs does it provide you with an error log? If so could you provide it please? Also I should note that I'm from Netduma so we didn't make this feature but I'll do my best to help.
