MrSwann
Nov 11, 2020Aspirant
XR500 OpenVPN suddently not working
Hi all My OpenVPN server suddently stopped working, can’t connect. I tried with ddns, didn’t do anything. I tried redownloading configs, didn’t help either What can I do ?
MrSwann
No, i got the unit and ran the setup etc. It worked fine for about a day, then it stopped working. Not I can’t connect either via phone nor pc. Also the profiles for pc doesn’t work, so I tested using mobile profile and that also worked shortly as I recall
Netduma-Fraser
Nov 12, 2020NetDuma Partner
Whatever VPN client you're using to connect with these configs does it provide you with an error log? If so could you provide it please? Also I should note that I'm from Netduma so we didn't make this feature but I'll do my best to help.
