Thorfinn
May 04, 2020Star
Xr500 or should i buy another model?
So let me first tell that i'm using an old d-link dsl-g256dg modem/router connected by a phone cable from my adsl adapter and a cat6 cable from the modem/router to my pc My Isp is the "best" one in m...
May 05, 2020Guru - Experienced User
You'll need to bridge the D-Link modem so it's a modem only with any router you decide to connect to it. You can try out the XR500 and see if it works well for you. It should.
Netduma-Fraser
May 05, 2020NetDuma Partner
As above I'd suggest putting the DLINK into modem mode, that saves you buying anything else and would also allow the XR to control all your devices. Given your bandwidth speeds you're very susceptible to local congestion/lag which the XR could definitely eliminate.
- ThorfinnMay 05, 2020Star
Hey
Thank ya'll for the comments.
I decided to take the chance and ordered the Router from NewEgg to my Country
I hope the proccess will be easy and will work and solve my issues (making my dlink a bridge and connect it to the XR)
- Netduma-FraserMay 05, 2020NetDuma PartnerGreat to hear that, let us know if you have any questions/issues.
- ThorfinnMay 10, 2020Star
Yo!,
So I got the router today and just finished installing and tweaking all the settings, took me a while because it's my first time messing with such things(make my old modem "bridge" and connect it to the new XR500 and configure pppoe and so on)
This is the best purchase i made in years...!
Fixed my bufferbloat
Fixed my Wifi signal (entire house got strong wifi connection)
And total control over my wifi/devices and so on!
Thank you Netgear for an amazing product!
