Gimli
Jan 19, 2019Tutor
XR500 OR XR700?
Is there a lot of difference between the xr 500 and the xr 700? Is it worth the exchange of the Xr500 for the XR700?
Thank you
- Jan 19, 2019
There is. Just depends on if you have the client side HW that supports higher connection rates (AD) on wireless to take advantage of it and really need SPF media port support.
You can compare modes with the data sheets:
https://www.netgear.com/images/datasheet/networking/wifirouter/XR700.pdf
https://www.netgear.com/images/datasheet/networking/wifirouter/XR500.pdf
Jan 19, 2019Guru - Experienced User
Netduma_Jack
Jan 21, 2019NetDuma Partner
XR700 also has Plex server support.
But DumaOS is the same on both.
