sev7nflow
May 15, 2020Apprentice
XR500 Packet Loss and Latency gaming
Hi, I just bought this router and have been experiencing packet loss and issues ever since I swapped routers. Ive been monitoring the packet loss on PingPlotter Pro and every few minutes experien...
Netduma-Fraser
May 16, 2020NetDuma Partner
Are you seeing packet loss on the hops (which is normal) or are you seeing red bars on the bottom graph?
sev7nflow
May 17, 2020Apprentice
I'm seeing thick red horizontal bars on the plot on the bottom graph
- Netduma-FraserMay 18, 2020NetDuma PartnerWhat target are you using? Is this when nothing is using the internet or when it is saturated? Are you using QoS?
- sev7nflowMay 18, 2020Apprentice
I'm checking twitter and google as targets. This is when my desktop is either streaming a video, or gaming. I was using QoS but it just slowed it down even more so I went to all default settings to check. Same issue
- Netduma-FraserMay 18, 2020NetDuma PartnerWithout anything using the internet do you receive packet loss? If you're using applications/services then you should definitely use QoS. Could you provide a screenshot of your results please?
