tirane
Jan 14, 2018Follower
XR500 parental control
Hi, Will the XR500/ the current OS has parental control? thanks.
Netduma-Fraser
Jan 14, 2018NetDuma Partner
DumaOS integrates with Netgears settings so yes you should be able to use parental controls as normal.
- Netduma-FraserJan 14, 2018NetDuma PartnerSorry please ignore my previous post. It has been removed from the software.
