aeloen
Nov 14, 2020Aspirant
XR500 Parental Controls
Hi, Is there any update as to when parental controls will be delivered for the XR500? Thanks
Netduma-Fraser
Nov 14, 2020NetDuma Partner
If you upgrade to the 3.0 beta then you will have access to the Parental Controls (Traffic Controller).
- aeloenNov 14, 2020AspirantHi,
Thanks for your reply. I've had the router 24 hrs, where can I get the beta from?
Appreciate your help.- Netduma-FraserNov 15, 2020NetDuma PartnerYou can find it here: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/bd-p/en-home-beta-npg-duma
- TBigJohnMar 06, 2021Aspirant
Hi, Are you sure it's possible to use this Beta 3.0 on XR500 ?
Possible to have a direct link to the right version ?
Thanks
