aeloen
Nov 14, 2020Aspirant
XR500 Parental Controls
Hi, Is there any update as to when parental controls will be delivered for the XR500? Thanks
Netduma-Fraser
Nov 14, 2020NetDuma Partner
If you upgrade to the 3.0 beta then you will have access to the Parental Controls (Traffic Controller).
aeloen
Hi,
Thanks for your reply. I've had the router 24 hrs, where can I get the beta from?
Appreciate your help.
- Netduma-FraserNov 15, 2020NetDuma PartnerYou can find it here: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/bd-p/en-home-beta-npg-duma
- TBigJohnMar 06, 2021Aspirant
Hi, Are you sure it's possible to use this Beta 3.0 on XR500 ?
Possible to have a direct link to the right version ?
Thanks
- Netduma-FraserMar 06, 2021NetDuma PartnerYes absolutely certain, here is the latest for you to try https://www.dropbox.com/s/4mwe5sx81gsc129/XR500-V2.3.2.114-DumaOS3.0.203.img?dl=0
