NDwsn
Jul 09, 2020Aspirant
XR500 PC disconnects
My pc has been intermittently disconnecting, I have tried a new Ethernet cable, and I have tried it in every port on the router. Nothing else disconnects, not my WiFi or other wired devices. It someti...
Netduma-Fraser
Jul 09, 2020NetDuma Partner
If you connect the same PC to WiFi, do you experience the same issue?
- NDwsnJul 10, 2020AspirantI don’t have a WiFi card in my pc to try that but as I said all the other devices on my network remain connected to the internet when the issue is happening
- Netduma-FraserJul 10, 2020NetDuma PartnerIf you connect the PC directly to your ISP hub/modem do you experience the same issue?
