TTNorth
Jun 15, 2019Guide
XR500 Ping ramping up and down.
I have had a XR500 for about 3 weeks and I have nothing but problems. In game the ping is ramping up and down constantly. I connect to Telstra Bigpond ADSL2+ with the smart modem in bridge mode. I a...
Netduma-Fraser
Jun 15, 2019NetDuma Partner
The speed at which is increases and then decreases indicates that it's likely a server side issue or a local congestion issue. Could you follow this guide please and see if that resolves the issue: http://support.netduma.com/en/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos
- TTNorthJun 15, 2019Guide
I have narrowed it down to a wifi issue with the Netgear A6210 USB Dongle in my kids computers. I hard wired the computer and played Overwatch and it does not ramp up and down. I changed channels etc... but it still does it.
I just plugged an old TP link 300mbps USB dongle into kids computer with wifi and it does not ramp up and down. There is an issue with the A6210 and the XR500 together
Edit. I have 2 kids which means 2 computers the same and 2 Netgear A6210's which both do the same thing.
- Netduma-FraserJun 16, 2019NetDuma PartnerWell done finding the cause, it might be a good idea to create a support ticket as they're both Netgear products: http://support.netgear.com/
Did you use a WiFi analyser to check for the best channel before testing it? Are you using Smart Connect for WiFi? If so the adapter might not be interacting nicely with that so try disabling it and connecting the adapters to the individual 2.4/5GHz WiFi. Also recommend using 2.4GHz for gaming as it is more stable.
