Tigsman
Jan 29, 2020Tutor
XR500 port assignments backwards?
so looking in the DumaOS(.56) device manager (list view is simpler) I recently noticed that port 1 is currently 100mb, the other 3 1000mb. However, on the router itself, its not port 1, but Eth 4 li...
- Jan 29, 2020Okay in that case it might be something we need to look into ourselves. If it is an issue for you downgrade and check if it reports correctly.
Netduma-Fraser
Jan 29, 2020NetDuma Partner
Did you notice this on previous versions of the firmware? If not then it's an aesthetic bug we'll need to fix. If you did then did you buy the router very early on when it was announced? If so there were a batch of routers that had this incorrect assignments just affecting the aesthetics and not performance.
Tigsman
Jan 29, 2020Tutor
i know that eth4 is the 100mb connection (direct connection to Phillips Hue hub), has been since i got it. I just recently noticed the port assignments in the DumaOS, not sure how long it has been that way. port 4 in back of router and eth4 light in front seem to correspond correctly. DumaOS seems them backwards. As for when i got it, my 1 yr service agreement expired a short time ago 1-3 months.
- Netduma-FraserJan 29, 2020NetDuma PartnerOkay in that case it might be something we need to look into ourselves. If it is an issue for you downgrade and check if it reports correctly.
- TigsmanJan 29, 2020Tutor
Okay in that case it might be something we need to look into ourselves. If it is an issue for you downgrade and check if it reports correctly.no issue for me, now that I know what to look for. I suspect its just a pointer on your side for the ports. I only notice in the Admin Panel of DumaOS. I know I have a managed switch in port 1 and not a single device, which led me to this conclusion. DumaOS shows 5 devices on port 4 (all from my switch), not 1.
T
- Netduma-FraserJan 29, 2020NetDuma PartnerOkay great, thank you for the information we'll look into it. Like I said it won't affect your performance at all so no need to worry about that.
