rothnd
May 22, 2024Aspirant
XR500 Port Forwarding
Howdy! I am stumped after being at this most of a week. I am trying to open a couple ports through my Nighthawk XR500 V2.3.2.134 running DumaOS. When I use the grc Shield's Up scanner, it shows all (...
- May 23, 2024
It's either or. uPnP works in most configurations. Specialized configurations, needs to be disabled.
rothnd
May 23, 2024Aspirant
Quick update - did a bunch of troubleshooting today with some techies’ help. Things learned - I’m not behind CG NAT/double NAT. The problem appears to be with the XR500. Some zone/security/something or other is not allowing the opening of ports on my network. Please help if you can!
- FURRYe38May 23, 2024Guru - Experienced User
Is uPnP disabled if you have any PF configurations setup?
