wub901
Jun 10, 2018Guide
XR500 PPOE Bug
Might have found a bug on setup with the latest firmware it detects my connection as ppoe which it is however it leaves it as dial on demand and I have no internet until I change it to always on.
wub901
Jun 11, 2018Guide
Maybe but on the XR500 the speedtest fails as it sets my connection to dial on demand then you have to re run the setup again to get a speedtest which is why it would be a good option to add a speedtest option without having to run setup again.
Netduma-Fraser
Jun 11, 2018NetDuma Partner
You don't need to redo the setup just for a speed test. Can go to speed test manually and input the results into Anti-Bufferbloat. We do want to add the option though.
