PINGIU987
Jan 05, 2019Aspirant
xr500 problemi in game
dopo una partita che gioco va bene ma dalla seconda in poi mi crasha in game dopo continua a darmelo e sena risultati se si può fare qualcosa
PINGIU987
Jan 06, 2019Aspirant
after a game I play okay on then crashes me into play after keep giving it to me and senain if you can do anything
Jan 06, 2019Guru - Experienced User
What do you mean by craches?
- Netduma_JackJan 07, 2019NetDuma Partner
Which router do you own?
And could you explain what you mean by it crashing?
- PINGIU987Jan 07, 2019Aspirant
netgerar xr500
for ceash I mean that when I play two consecutive games, he throws me out of matchmaking and does it afterwards- FURRYe38Jan 07, 2019Guru - Experienced User
Does this happen with other games you play?
How is your console connected to the router? Wifi or wired? Wired is preferred.
What FW is currently loaded?
